I'm having a problem after update
alrase
alrase
Mon Sep 16, 2013 8:32 am
#1 by alrase
After the update to 6.95.2 and 6.95.3 become encrypted channels Al Jazeera Sports is not working
Please I want a solution to the problem quickly and thank you
  • Mon Sep 16, 2013 8:46 am
Re: I'm having a problem after update
Do you still use x32?
  • Mon Sep 16, 2013 2:32 pm
alrase
alrase
#3 by alrase
yes
  • Mon Sep 30, 2013 8:33 pm
alrase
alrase
#4 by alrase
Today you update to the new version, but the same problem note that the original version !!!
  • Mon Sep 30, 2013 8:35 pm
#5 by Prog
.2 still working? Please send me logs.
  • Tue Oct 01, 2013 4:49 am
alrase
alrase
#6 by alrase
What is the path of the file ?
  • Tue Oct 01, 2013 12:25 pm
#7 by Prog
Settings->Options->Debug
  • Tue Oct 01, 2013 12:52 pm
alrase
alrase
#8 by alrase
The file attachments teacher
logprog.zip
(1.9 KiB) Downloaded 218 times
  • Tue Oct 01, 2013 1:38 pm
#9 by Prog
Please restart ProgDVB after enable of logs. Not logs in this zip.
  • Tue Oct 01, 2013 3:26 pm
alrase
alrase
#10 by alrase
The file attachments teacher again
NewLog.zip
(9.29 KiB) Downloaded 218 times
  • Tue Oct 01, 2013 7:53 pm
alrase
alrase
#11 by alrase
Is there a solution to the problem?
  • Wed Oct 02, 2013 2:22 pm
#12 by Prog
You not have signal in last log.
Try .5 version _x32_
  • Thu Oct 03, 2013 5:19 am
alrase
alrase
#13 by alrase
Deleted the program and re-install the program and now returned signal but also the channel does not work
Was attached to the new log file
LOG2.zip
(10.44 KiB) Downloaded 206 times
  • Thu Oct 03, 2013 2:11 pm
alrase
alrase
#14 by alrase
Is there a solution to the problem or not ؟
Thank you
  • Sat Oct 05, 2013 9:43 am
  • It is currently Mon Aug 24, 2026 3:35 pm
