I've tried everything and nothing ... sometimes works sometimes does not work ...
Already changed codek already changed demultiplexor and nothing...
The version 6.93 works well with any setting, but later versions no run at all ...
I have windows 8.1 x64 with a tv card AverMedia AVerTV Volar HD PRO
Re: After version 6.93 the audio stopped working
#2What audio type? Use ac3filter of other freeware codec for AC3.
#3The audio channel television (DVB-T) in principle should be the MPEG but not sure ...Prog wrote:What audio type? Use ac3filter of other freeware codec for AC3.
The only thing I know is that version 6.93 works with any configuration, but after that no version is working again ...
#4You can look in channel info window or File->Direct show.
#5The thing is, the image appears but does not give any sound ...Prog wrote:You can look in channel info window or File->Direct show.
I have version 6.93 on a folder and it works ...
From version 6.93 works fine without any error but when I try to simply watch TV (the same channels that work well in version 6.93) in the following versions the image appears but does not give any sound ...
PrintScreen:
http://megaimg.com/images/88246172103119652471.pngRe: After version 6.93 the audio stopped working
#7I've tried all combinations but still does not workProg wrote:btw, try change audio renderer in settings.
#9the link will log folderProg wrote:Send me ProgDVBEngine.log
https://mega.co.nz/#!JAdhSZ4Z!AaOQZUHFcAavuac843kKYhHRLh9xZTLmnwJDS_Wr0AIRe: After version 6.93 the audio stopped working
#11I am not can download from this link. Please send me file on email.
#12ok sorry...Prog wrote:I am not can download from this link. Please send me file on email.
then by sending attached...
Taking the opportunity to ask if there is any way for the remote control (RM-KS) of my tv card (AverMedia AVerTV Volar HD PRO) to work with the program ProgDVB
- Logs.rar
- Logs
- (98.05 KiB) Downloaded 356 times
#13No any errors. But try change audio renderer. For example to System.
#14I already done that...Prog wrote:No any errors. But try change audio renderer. For example to System.
I already tried all combinations of audio renderer but it only works from time to time, but when I change the channel stops working again...
I think I've found the problem...
In version 6.93 the audio channel is identified as AAC audio and works well...
But in the following versions the audio channel is identified as MPG and audio does not work...
I think the problem may be that...
but do not know how to solve...
#15Yes, this is possible. Can you record me sample of channel? 3-5 minutes.
