Problem registring the Cyberlink Power dvd codec!
#1Hi guys,I've been experiencing a problem registring the power dvd codecs in Progdvb.Can you guys tell me exactly witch two .ax files I need to decode the mpeg2 and h264 channels?I've tried several of the .ax files and ,copied them in the "Filters" folder ,I've edited the "register" file saved it,ran it,so the codecs should be visible in the list of codecs in the "Options" menu ,but they aren't ,so what am I doing wrong? Thanks in advance .
