ProgDVB 6.97.02 Prof 8000 and DiSEqC
Been using the standard edition of older versions of ProgDVB for years. Finally used some Christmas money and upgraded to the professional version this week. I'm sure this is something simple but I can't seem to locate where to define the LNB for the 2 ports on my DiSEqC switch.
In the past I found the location to assign the satellites to the C & Ku LNB's. Under TV Sources for my receiver card I see LNB. But there is no choice on a given satellite to have Position 1 on the DisEqC for C band and position 2 for Ku. It's either assigning ALL the satellites I choose under "More than One position" as C Band or Ku Band. But it won't let me do both.
The only thing I can figure out is there is a blank field on the satellite check off list. I'm guessing there is some notation that goes in there to define the satellite as C or Ku (or both). But I can't determine what that notation should be. I tried 0,1 and 1,2 but neither of those seemed to do anything.
Thanks in advance for your help.
