Hello!
Last version that work fine with my USB TV-stick TechnoTrend TT4400 is v7.04.02.
Both x32 and x64 version.
After that version all version which i tested enter in crash loop after starting the program.
In case of upgrade from version v7.04.02 ProgDVB enter in loop imediatly.
In case of uninstall and fresh install, scaning and configuration works and after selecting a channel works, but when i change the channel crash and enter in crash loop: restart - crash -wait - restart - crash etc...
After any test that not work i install v7.04.02 and this work fine.
My setup is: win8.1 x64 +Technotrend TT4400 TV-stick.
Someone experienced same things? Is some workaround?
Re: ProgDVB enter in crash loop!
#3OK.
I reinstall it again and works fine until i close it.
When i start-it again enter in crash loop.
Logs are in the attachment.
2. Technotrend.eBDA2 i do not find it... Technotrend.eBDA i removed an no change...
- Logs.zip
- (3.67 KiB) Downloaded 200 times
#4My solution for this loop restart:
1. Uninstall with remove all settings.
2. Install again.
2. Install again.
#5Thanks for reply!
Yes, it works, but only if i keep ProgDVB running.
Works channel switching, configurations, scanning, etc.
But after i close ProgDVB and i open it again, enter in crash loop.
#7Ok!
Is attached.
Is attached.
- ProgDVB.zip
- (3.59 KiB) Downloaded 196 times
#8Still not have good idea. But try add to ProgDVB.ini
[BDA]
SetIsNotStartMoreOneDeviceAtOnce=1
and remove technotrend.ebda
[BDA]
#10Ok.
Procedure not work, but after insert that line in progdvb.ini only two logs are created...
Last logs is attached.
If helps, v7.04.02 work fine. From there all new versions installs ok and works fine until first close of ProgDVB.
After reopen enter in crash loop.
- Logs.zip
- (13.08 KiB) Downloaded 219 times
#12Hello!
With last prerelease, problems are gone!.
I install it, configuration and channel switching is ok.
I restarted ProgDVB, works fine, restart PC, start again ProgDVB and works fine.
I make some more restarts seems to be fine.
Prog, thanks for your promptitude and ability for solve the problem!
