Hi, Prog,
I use ProgDVB 7.05.8 for my home TV server("Open channels without playback" is checked)
OS: Windows 7 Home Premium x64 (updated)
ProgDVB can't restore window from tray icon after hours or days of usage(I have this problem with all old versions) without timeshift buffer(disabled).
I have this problem with x86 and with x64 version of the program.
BUT if timeshift buffer is enabled I don't have this problem. My setting for timeshift buffer is 100MB/2000KB/s in the memory and program window work very fine from tray icon.
Sorry for my very bad english.
Re: ProgDVB can't restore window from tray icon
#2Do you have this problem after start or after some hours of using? Try enable logs.
#3Only after some hours of using. I have this problem from many time(+1 year).
Now I set timeshift buffer and the program work fine.
#5Forgot my solution, Prog.
I have sheduled task(with 2 minutes delay) with ProgDVB after user logon. ProgDVB started normally but I can't restore window. Right click and Restore... nothing. Repeat and... nothing. Right click and EXIT... nothing. Right click and NO RIGHT CLICK MENU.
ProgDvbNet.exe in Task Manager has 25% CPU(Quad-core CPU) and 36MB RAM.
Closing with End Process.
Start ProgDVB from the icon - work fine.
Logs attached!
Logs attached!
- logs.zip
- (262.43 KiB) Downloaded 237 times
#7No, program start normally after logon(logon in Windows) with scheduled task(with 2 minutes delay).
Task scheduler started ProgDvbNet.exe without optional parameters.
#8Thanks. I check this later. But you can try some experiments with rights. MS scheduler working in system rights and not have access for some resources.
#9Task scheduler run ProgDvbNet.exe with my account rights(Administrator account).
I have another problem with exit.
Open program window and clicked on X. After this program is "Not responding". I clicked many times on X for force close.
Logs attached! Remark ProgDVBEngine.log is around 180MB only after 7 hours of usage fill with "TimeShift::CheckOverfill". WTF?!
Logs: http://93.xx.xx.xx/Logs2.zip (8MB)
#10What so many losted packets?
02:44:55.010 - * s:74 q:89 tr=5428500 (10152)
#11I don't know.
The packets is losted from DVB-C tuner or from LAN networks?
Now I have 1.28% lost from DVB-C signal, but I don't have any problem with the picture and sound.
Screenshot attached.
- screenshot.png (31.03 KiB) Viewed 8145 times
#12Close the program in system tray with right click and EXIT. Open the program again from the icon and I can't open the program window.
My settings:
CHECK - Show icon in system tray
UNCHECK - Show in taskbar
CHECK - Restore window mode
If
UNCHECK - Restore window mode
I can open the program window but it is very small(before manual resize).
Please, check this, Prog.
My settings:
If
#13Do you have more one display or some exotic configuration? ProgDVB must normal start in this situation. I was check again 5 minutes ago.
#14No. I have only one monitor.
CORSAIR CX500 500W
AsRock AliveNF6G-DVI
AMD Phenom x4 9650 (stock clock)
SAPPHIRE HD5450 (stock clock, installed last driver)
6GB RAM (2x1 + 2x2) DDR2 800MHz (stock clock)
3 HDD (500GB, 200GB, 80GB)
2 x LAN cards Realtek 100Mbps
Monitor LG 19" TFT
TV tuner TBS 6618 for DVB-C (installed last driver 1.0.0.4) without CI card
Microsoft Security Essentials (except ProgDVB process)
This is old machine but it work very stably.
Try this, Prog:
Minimize ProgDVB only in system tray! And...
P.S.: On Windows 8.1 work fine.
CORSAIR CX500 500W
Monitor LG 19" TFT
Try this, Prog:
My settings:
If
