How to total disable timeshift?
kamilooo
kamilooo
Wed Jul 09, 2014 2:57 pm
#1 by kamilooo
Welcome. I have ProgDVB 7.05.8. The options have a timeshift function off. Although it is still possible to stop the channel. How does it completely off?
  • Wed Jul 09, 2014 3:00 pm
Re: How to total disable timeshift?
Same like in old versions. ProgDVB not use special buffer for timeshift and impossible disable it. Only set to minimal size.
  • Wed Jul 09, 2014 3:40 pm
kamilooo
kamilooo
#3 by kamilooo
I understand. However, in older versions of the timeshift off buttons play, stop, pause were inactive, and here they are and I can still stop the channel.
Where to set the buffer size?
  • Wed Jul 09, 2014 4:27 pm
#4 by Prog
Hm. What last good version?
  • Wed Jul 09, 2014 4:30 pm
kamilooo
kamilooo
#5 by kamilooo
Recently I had the version 7.05.2 and it was all right. Revisions 3-7 not tested.
  • Wed Jul 09, 2014 4:34 pm
#6 by Prog
Please test "b" prerelase.
  • Thu Jul 10, 2014 10:05 am
kamilooo
kamilooo
#7 by kamilooo
Ok. This version is ok, but after the installation has been enabled additional channel list - recordings, favorite...
Thanks
  • Thu Jul 10, 2014 10:28 am
#8 by Prog
You can disable in Channel list->Edit. New version not import some old settings.
  • Thu Jul 10, 2014 10:55 am
  • It is currently Mon Aug 24, 2026 6:32 pm
