I need to buy "Register MPGEG-2 codecs" ?
wsleone
wsleone
Tue Jul 15, 2014 2:55 pm
#1 by wsleone
Good afternoon
I buy ProgDVB Professional x32 bits (now I have installed the trial version 21 days) and I have two questions:
(( I have Windows 7 Ultimate 64bits + SP1 + all updates ))
1.- I need to buy "Register MPGEG-2 codecs" ?
2.- What is the option in EPG -> Tools -> Update ?
Regards
  • Wed Jul 16, 2014 6:25 pm
Re: I need to buy "Register MPGEG-2 codecs" ?
1. Win7 have self not bad codecs. You can select Options->Video->Codec->mpeg=microsoft
2. For example update all epb base for satellite.
  • Thu Jul 17, 2014 5:45 am
wsleone
wsleone
#3 by wsleone
Prog wrote:1. Win7 have self not bad codecs. You can select Options->Video->Codec->mpeg=microsoft
Thanks Prog :D
I already purchased ProgDVB Prof. and activate with key
Other question: Are there any Spanish translation for 7.xx.xx versions ?
Regards
  • Thu Jul 17, 2014 2:45 pm
#4 by Prog
No :(
  • Thu Jul 17, 2014 2:50 pm
  • It is currently Mon Aug 24, 2026 8:14 pm
