SkyStar 2 eXpress HD: conflict with AirStar 2
Hi,
Recently I switched from SkyStar HD2 [R.I.P :(] to SkyStar 2 eXpress HD.
In the beginning the new RC module didn't work. I found a topic with information that SkyStar 2 eXpress HD must be added to ProgDVB sources as WDM device (not BDA). It was good solution but since this change I can't use my second card AirStar 2 any more.
When I have both devices connected to my PC and enabled in Windows Device Manager, ProgDVB detects AirStar 2 as SAT tuner (but it's terrestrial):
When I try to enable the second device (WDM SkyStar 2 eXpress...) ProgDVB adds it as "Internet TV and Radio":
If I disable AirStar 2 in Windows Device Manager...
... ProgDVB detects SkyStar 2 eXpress HD correctly:
When I use SkyStar 2 eXpress HD as BDA device and AirStar 2 as WDM device, ProgDVB works correctly with both cards in the same time, but RC module doesn't work (because of BDA...).
Additionally, when I do any changes in ProgDVB sources when both cards are enabled as WDM in many cases crash occurs.
I attach some logs.
My OS is Windows 8 64-bit.
I use the latest version of ProgDVB Pro.
Driver version of SkyStar 2 eXpress HD is 4.7.0 (the latest one).
Could you check it?
Thanks
logs.zip
(2.32 KiB) Downloaded 370 times
