When I start progdvb it crashes and the progdvb restarting it self again it happen Several times .Sometimes the program works with the cut in the image. Then reboot with crash message.
Thanks
Re: ProgDVB pro x86 7.07.09 crashes on start
#3Thank you for the quick reply...Yes I can.In fact, Retry to send you ProgDvb log file in RAR compressed file As Attach. But unfortunately I could not upload it . I'll try again with the required files.
Thanks .
Thanks .
- ExceptionReportWith prog_ini.rar
- (6.35 KiB) Downloaded 216 times
#5ok my pc :
windows 8.1pro 64
Net FrameWork 4.5.1
vga Nvidia 590GTX drivers ver347.09
For the Second question. I did not understand? Did you mean ProgDvb Skin? . it is skin1
Please If you need more details just let me know
Thankyou
windows 8.1pro 64
Net FrameWork 4.5.1
Thankyou
#6You log is quite untypical for ProgDVB. I think some problem with .net (try reinstall 2.0) or video driver.
ps: Also try clean install ProgDVB to empty directory without any plugins.
#7ok I'll try with a clean install first. And inform you of the results.
Thanks
Thanks
#8Clean installation solved this issue
Thank's for your assist.
