Crashing after channel change
When I want to change channel in ProgTV using Up and Down keys, it always crash. If i choose the channel from channel list it works. Also channel changing using Up and Down works in ProgDVB. Any solution? Thanks
Here is log (open ProgTV, change channel - crash):
16:49:46.990 - Start logging...
16:49:46.991 - GetBdaTunerList
16:49:46.995 - tuner AVerMedia BDA Digital DVBT Tuner -  - \\?\pci#ven_1a0a&dev_6202&subsys_62051461&rev_01#4&286c230d&0&00e7#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{a138b8af-9b11-4591-8632-47e431e3062f}
16:49:46.996 -   AVerMedia BDA Digital DVBT Tuner ex:56068 type:DVB-T
16:49:46.998 - GetInfo 1
16:49:46.999 - CreateExtApi AverMedia 235
16:49:47.001 - CExtApiExternal avermedia - AVerMedia BDA Digital DVBT Tuner
16:49:47.003 - CExtApiExternal::load D:\Program Files\ProgDVB\Modules\avermedia.ebda 1
16:49:47.005 - Skip ebda2 module for {0}
16:49:47.007 - ~CExtApiExternal::Unload
16:49:47.008 - GetModuleInfo {BDA} AVerMedia BDA Digital DVBT Tuner 56068
16:49:47.010 - exIndex 0
16:49:47.011 - maxfilters 128
16:49:47.013 - caps 200b04
16:49:47.014 - PossibleStart 1
16:49:47.016 - CreateModule 56068
16:49:47.017 - CBDAManager
16:49:47.019 - BDAManager::Start 56068
16:49:47.020 - index 0
16:49:47.022 - CreateExtApi AverMedia 235
16:49:47.024 - CExtApiExternal avermedia - AVerMedia BDA Digital DVBT Tuner
16:49:47.026 - CExtApiExternal::load D:\Program Files\ProgDVB\Modules\avermedia.ebda 1
16:49:47.027 - Skip ebda2 module for {0}
16:49:47.029 - BuildGraph
16:49:47.035 - LoadNetworkProvider DVB-T
16:49:47.043 - GetTunerSpace DVB-T
16:49:47.045 - put_FrequencyMultiplier FAILED!
16:49:47.047 - get_FrequencyMultiplier FAILED!
16:49:47.048 - FrequencyMultiplier -1
16:49:47.050 - BW: 0
16:49:47.052 - Connecting NetworkProvider -> AVerMedia BDA Digital DVBT Tuner ... OK
16:49:47.057 - ReceiverComponents:
16:49:47.060 -    AVerMedia BDA Digital Capture - \\?\pci#ven_1a0a&dev_6202&subsys_62051461&rev_01#4&286c230d&0&00e7#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{7b926c54-9bd6-4a49-82f0-d8545b968667}
16:49:47.062 - LoadFilter
16:49:47.064 - Connecting AVerMedia BDA Digital DVBT Tuner -> AVerMedia BDA Digital Capture ... OK
16:49:47.068 - LoadFilter 1
16:49:47.070 - Connecting AVerMedia BDA Digital Capture -> Demux ... OK
16:49:47.074 - Connecting AVerMedia BDA Digital Capture -> Ts Sink ... OK
16:49:47.078 - Connecting Ts Sink -> Demux ... OK
16:49:47.081 - LoadFilter
16:49:47.083 - Connecting Demux -> BDA MPEG2 Transport Information Filter ... OK
16:49:47.087 - LoadFilter 1
16:49:47.089 - KillTifPids
16:49:47.264 - BuildGraph OK
16:49:47.269 - ExtApi->Create
16:49:47.271 - ExtApiExternal::Create main
16:49:47.336 - ISDB Region 0
16:49:47.337 - get_FrequencyMultiplier FAILED!
16:49:47.339 - FrequencyMultiplier 1000
16:49:47.341 - CTuneRequestSwitchManager 1
16:49:47.342 - CI_EnableCISupport 1
16:49:47.352 - DVB-T PLP supported hr=0x80070492 result=0
16:49:47.794 - UpdateOpenedChannels 1
16:49:47.804 - SetTransponder [{BDA} AVerMedia BDA Digital DVBT Tuner] 490000 - 8000
16:49:47.805 - SetPlpID 0
16:49:47.807 - SetPlpID not supported
16:49:47.809 - BW: 8
16:49:48.214 - KillTifPids
16:49:48.216 - KillTifPids
16:49:48.274 - UpdateOpenedChannels 1
16:49:49.488 - GetTunerState 1 - 0(100)/74
16:49:50.567 - GetTunerState 1 - 0(100)/100
16:49:51.629 - GetTunerState 1 - 0(100)/100
16:49:52.689 - GetTunerState 1 - 0(100)/100
16:49:53.787 - GetTunerState 1 - 0(100)/100
16:49:54.608 - Start logging...
16:49:54.610 - GetBdaTunerList
16:49:54.614 - tuner AVerMedia BDA Digital DVBT Tuner -  - \\?\pci#ven_1a0a&dev_6202&subsys_62051461&rev_01#4&286c230d&0&00e7#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{a138b8af-9b11-4591-8632-47e431e3062f}
16:49:54.616 -   AVerMedia BDA Digital DVBT Tuner ex:56068 type:DVB-T
16:49:54.618 - GetInfo 1
16:49:54.619 - CreateExtApi AverMedia 235
16:49:54.621 - CExtApiExternal avermedia - AVerMedia BDA Digital DVBT Tuner
16:49:54.623 - CExtApiExternal::load D:\Program Files\ProgDVB\Modules\avermedia.ebda 1
16:49:54.625 - Skip ebda2 module for {0}
16:49:54.626 - ~CExtApiExternal::Unload
16:49:54.628 - GetModuleInfo {BDA} AVerMedia BDA Digital DVBT Tuner 56068
16:49:54.630 - exIndex 0
16:49:54.632 - maxfilters 128
16:49:54.635 - caps 200b04
16:49:54.637 - PossibleStart 1
16:49:54.638 - CreateModule 56068
16:49:54.640 - CBDAManager
16:49:54.642 - BDAManager::Start 56068
16:49:54.644 - index 0
16:49:54.645 - CreateExtApi AverMedia 235
16:49:54.647 - CExtApiExternal avermedia - AVerMedia BDA Digital DVBT Tuner
16:49:54.649 - CExtApiExternal::load D:\Program Files\ProgDVB\Modules\avermedia.ebda 1
16:49:54.651 - Skip ebda2 module for {0}
16:49:54.653 - BuildGraph
16:49:54.657 - LoadNetworkProvider DVB-T
16:49:54.662 - GetTunerSpace DVB-T
16:49:54.664 - put_FrequencyMultiplier FAILED!
16:49:54.665 - get_FrequencyMultiplier FAILED!
16:49:54.667 - FrequencyMultiplier -1
16:49:54.669 - BW: 0
16:49:54.671 - Connecting NetworkProvider -> AVerMedia BDA Digital DVBT Tuner ... OK
16:49:54.675 - ReceiverComponents:
16:49:54.679 -    AVerMedia BDA Digital Capture - \\?\pci#ven_1a0a&dev_6202&subsys_62051461&rev_01#4&286c230d&0&00e7#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{7b926c54-9bd6-4a49-82f0-d8545b968667}
16:49:54.680 - LoadFilter
16:49:54.684 - Connecting AVerMedia BDA Digital DVBT Tuner -> AVerMedia BDA Digital Capture ... OK
16:49:54.688 - LoadFilter 1
16:49:54.690 - Connecting AVerMedia BDA Digital Capture -> Demux ... OK
16:49:54.695 - Connecting AVerMedia BDA Digital Capture -> Ts Sink ... OK
16:49:54.699 - Connecting Ts Sink -> Demux ... OK
16:49:54.703 - LoadFilter
16:49:54.705 - Connecting Demux -> BDA MPEG2 Transport Information Filter ... OK
16:49:54.708 - LoadFilter 1
16:49:54.710 - KillTifPids
16:49:54.885 - BuildGraph OK
16:49:54.887 - ExtApi->Create
16:49:54.889 - ExtApiExternal::Create main
16:49:54.952 - ISDB Region 0
16:49:54.954 - get_FrequencyMultiplier FAILED!
16:49:54.956 - FrequencyMultiplier 1000
16:49:54.958 - CTuneRequestSwitchManager 1
16:49:54.959 - CI_EnableCISupport 0
16:49:54.965 - DVB-T PLP supported hr=0x80070492 result=0
