Can't record test channel's with H.265/HEVC (2160p) (SAT)
Padman
Padman
Wed Feb 11, 2015 9:34 pm
#1 by Padman
Hello,
I tried a recording from some test channel's via SAT with codec H.265/HEVC with 2160p, but no video will be recorded.
Is it possible to record the streams completely?
Thank you :)
Regards/Gruß
Padman
  • Wed Feb 11, 2015 9:44 pm
Re: Can't record test channel's with H.265/HEVC (2160p) (SAT
You can try Service->TS recorder also.
  • Thu Feb 12, 2015 7:43 am
Padman
Padman
#3 by Padman
Prog wrote:You can try Service->TS recorder also.
It doesn't work. Only audio will be recorded :?
Regards/Gruß
Padman
  • Sun Feb 15, 2015 4:34 pm
#4 by Prog
TS Recorder can record stream is as (in All TS mode). Then problem in playback.
  • Sun Feb 15, 2015 6:09 pm
Padman
Padman
#5 by Padman
Update:
MediaInfo doesn't display the infos :?
I checked, PotPlayer can play the files, more or less.
But my hardware is for 4K to weak :roll:
Regards/Gruß
Padman
  • Sun Feb 15, 2015 10:01 pm
  • It is currently Mon Aug 24, 2026 1:56 pm
