Hi!
I was using ProgDVB Pro for a longer time without any problems. All worked fine. But now, after upgrading my PC (mainboard, memory, CPU), and a new fresh installation of Windows and all required drivers it always crashes and restarts, then it crashes again, restart, crash, restart and so on...
Channel search works fine, but if i switch to a channel, then it ends in a crash loop...
My system:
mainboard: ASRock 970 Extreme3 R2.0
CPU: AMD FX_8350 Eight Core CPU 4000MHz
RAM: G.Skill F3-12800CL9D-8GBRL Ripjaws Series DDR3-1600 PC3-12800 (2x 4096 MB)
Windows 7 Ultimate 64 bit
Soundcard: Infrasoic Quartet (a professional studio soundcard)
Graphic card: Nvidia G-Force 9600 GT
TV tuner: Hauppauge WinTV-HVR930C USB Stick
.NET Framework 3.5.1
Edit: Sometimes it doesn't crash, but then, after choosing a channel, the screen will stay black. And after a while the program freezes and i have to kill it...
Log Files attached.
ProgDVB Pro crashes, again and again and again...
#1- Attachments
- Logs.zip
- all available log files of ProgDVB Pro
- (14.93 KiB) Downloaded 178 times
