progdvb 7.08.02 pro time shift buffer not work !
star
star
Sat Jul 23, 2011 11:05 pm
#1 by star
-try codec no change
  • Sat Feb 21, 2015 6:35 am
Re: progdvb 7.08.02 pro time shift buffer not work !
Please test prerelease.
  • Sat Feb 21, 2015 7:22 am
star
star
#3 by star
Prog wrote:Please test prerelease.
work good but when select ( not close device and buffer of old channel........ )
when back time shift and record the record is not sync. not correct the screen display think and the record is other think !
other function not tested !
-all channels from transponder store in buffer !
  • Mon Feb 23, 2015 10:09 pm
#4 by Prog
Same problem with old version? All channels are free?
ps: This mode quite extreme :)
  • Tue Feb 24, 2015 6:55 am
  • It is currently Mon Aug 24, 2026 6:34 pm
