Unified Remote support
Anakunda
Anakunda
Sun Apr 10, 2011 12:28 pm
#1 by Anakunda
Hi
trying to write ProgDVB custom remote for UR app.
I have two questions:
- What are all window message codes for player control?
- What happened with F5-F8 keys, what are keyboard equivalents of R-G-Y-B teletext keys from TV remote?
  • Sun Mar 08, 2015 11:15 am
Re: Unified Remote support
You can looks list of commands in Options->Controls.
Use command like or window interface..
  • Sun Mar 08, 2015 3:35 pm
Anakunda
Anakunda
#3 by Anakunda
Thank you. Is ProgDVB handling commands through WM_COMMAND message?
I see no the list.
  • Sun Mar 08, 2015 3:51 pm
#4 by Prog
ProgDVB not have WM_COMMAND interface.
  • Sun Mar 08, 2015 7:12 pm
Anakunda
Anakunda
#5 by Anakunda
So the only way to control ProgDVB is by keyboard and mouse? Most programs handle their commands via GetMessage(...) loop so they can be controlled from outside.
  • Sun Mar 08, 2015 7:51 pm
#6 by Prog
May be remote control API is best for you?
http://www.progdvb.com/pluginapi.html
  • Mon Mar 09, 2015 8:14 am
Anakunda
Anakunda
#7 by Anakunda
Okay, but I don't know quite clearly which actions to generate with UR app to invoke remote control events in PC
https://github.com/unifiedremote/Docs/tree/master/libs
  • Mon Mar 09, 2015 8:21 am
#8 by Prog
In Settings->Controls.
Please mail me. I send you some header files.
  • Tue Mar 10, 2015 12:58 pm
  • It is currently Mon Aug 24, 2026 5:03 pm
