Diseq (LNB 2, LNB3, LNB4) Does not Work
Hamza Sadiq
Hamza Sadiq
Sat May 16, 2015 11:23 am
#1 by Hamza Sadiq
Hi there
will appreciate if any one helps to solve the problem of no signal and no channel search on LNB 2,3,4 while the signal and channel search are OK on LNB 1 , Tested on a receiver all 4 LNB are Ok , where the problem
I am using AvereMedia BDA
  • Sat May 16, 2015 11:39 am
Re: Diseq (LNB 2, LNB3, LNB4) Don Not Work
Check Settings->Device options->Mode
  • Sat May 16, 2015 12:07 pm
Hamza Sadiq
Hamza Sadiq
#3 by Hamza Sadiq
thanks for your quick reply
On setting scroll down
I have TV source & Option , where i could see the (device option) and (Mode)
  • Sat May 16, 2015 1:00 pm
Hamza Sadiq
Hamza Sadiq
Re: Diseq (LNB 2, LNB3, LNB4) Does not Work
#4 by Hamza Sadiq
Any Help Please
  • Mon May 18, 2015 2:45 am
#5 by Prog
Try select other mode. Microsoft for example.
Settings->name of device
  • Mon May 18, 2015 9:47 am
Hamza Sadiq
Hamza Sadiq
#6 by Hamza Sadiq
Tried all modes but non of them works
  • Thu May 21, 2015 3:23 am
#7 by Prog
x32? Do you have problem in other software?
  • Thu May 21, 2015 6:29 am
Hamza Sadiq
Hamza Sadiq
#8 by Hamza Sadiq
Win 7 64 i have no problem with other software
  • Thu May 21, 2015 4:21 pm
#9 by Prog
Try x32 version of ProgDVB at first.
  • Thu May 21, 2015 6:30 pm
Hamza Sadiq
Hamza Sadiq
#10 by Hamza Sadiq
Many thanks for your continuous support
I have again tried x32 version but with no success
where is the problem?
i have been using ProgDVB since 2002 and this is first time I have problem with this great and wonderful software
Hope the solution will come soon
  • Sat May 23, 2015 2:04 pm
#11 by Prog
I am not can really help you before 16.06. But you can try other modes.
  • Wed May 27, 2015 8:54 am
Hamza Sadiq
Hamza Sadiq
#12 by Hamza Sadiq
Any outcome , on this
  • Thu Jul 02, 2015 6:02 pm
Hamza Sadiq
Hamza Sadiq
#13 by Hamza Sadiq
Await your support on this please help
  • Thu Sep 24, 2015 5:50 am
#14 by Prog
I am not have idea why not working. You must select in device options manufacture of DVB card.
  • Thu Sep 24, 2015 6:27 am
  • It is currently Mon Aug 24, 2026 11:13 am
