ProgDVB and SS2 Support
1 post
ssss25
ssss25
Mon Mar 05, 2007 2:26 am
#1 by ssss25
Hi,
I've got Skystar2 PCI card and I do cannot scan any pictures. I ahve had issues like this in the past using MYtheatre and I found that is happening because I have a Diseq Switch, and the switch only worked with MT only when I used Advanced Drivers as per My theatre naming. Does anyone have SS2 working with a switch? If so, can you please help me if there is anything special I need to do?
Thanks.
  • Mon Mar 05, 2007 2:33 am
1 post
Return to “Hardware”
Thanks for report. This bug already fixed. Please wait ProgTV3 update.
Prog, Fri Sep 25, 2026 10:10 am
Updating Channels -Last Impor…
Hi! I'm having this situation: I installed last two versions (3.14.4 and 3.14.5), just to be updated, but i noticed when
AndresMaxx, Thu Sep 24, 2026 2:28 am
  • It is currently Mon Sep 28, 2026 1:35 pm
