Re: heeelp
#2Try install ProgDVB to c:\ProgDVB (not to program files). Look like no access to directory.
Re: heeelp
#3Ok, I found the problem! In the Italian language lacks the keys "OK" and "Edit" in the bind keys / control! and so you can not save your settings!Prog wrote:Try install ProgDVB to c:\ProgDVB (not to program files). Look like no access to directory.
Now I have another problem
Re: heeelp
#5How should I do? because I reinstalled the program and I deleted everything. I have to schedule a recording and then send the log file? where is it? Thank youProg wrote:Send me logs.
When in the settings of Scheduler I select "use progdvb service ... etc etc." I get out a warning box that says "it is no access rights for the service". Why ? thank you
Re: heeelp
#7With admin rights can select the setting without being outside the error. But does not record! where I find the log file? Thank youProg wrote:Try start ProgDVB with admin rights.
Re: heeelp
#9Which log file? in Scheduler.log there is a mistake and it is: "Error: Open OpenService FAILED.".However, it does not reference clock which is not match the recording. The time starts from the moment I opened ProgDVB. The service ProgDVB to record shows no signs of life.Prog wrote:In options->Debug
