Hi Prog,
ProgDVB 7.10.3x64 standard
New instalation from scratch.
Timeshift disabled.
Portable instalation.
No remote control module.
Unchecked mark for Youtube...
I have 2 tuners. One DVB-T and one DVB-C.
I wish disabled Youtube and DVB-T from TV source but when I clicked on Disabled the program is "Not responding". After many click on the X the window is closed but the process ProgDvbNet.exe still running in backround and I can't close this process from Task Manager.
Same problem with x86 version.
Everytime if I wish to disable one TV source the program is "Not responding" and need reboot my PC.
More than 10 reboots and nothing...
Re: I can't disable TV source
#2Please enable logs (Settings->Options->Debug) and send me all logs files after next crash.
#4ProgDVB 7.10.3d x86 Standard -> Same problem. I clicked simply OK for TV source and checked Logs. I clicked OK and after Yes for restart the program => Not responding. And... reboot... because ProgDvbNet.exe still running...
OS: Windows 7 Home Premium x64 - updated
#5After restart of PC:
Open ProgDVB
Check the Logs settings(the Logs has been checked)
Click OK
Close the program
"Not responding"
Logs attached
Open ProgDVB
Click OK
Close the program
"Not responding"
Logs attached
- Logs.zip
- (12.63 KiB) Downloaded 237 times
#6My solution:
Detele ProgDVB.ini and start the program with default settings.
