"BDA.device" (TDT) solution for ProgDVB modern versions
pascualet25
pascualet25
Sat Aug 15, 2015 11:50 pm
#1 by pascualet25
Technisat Airstick USB for viewing TDT works in modern versions of ProgDVB if you substitute archive "BDA.device" file from modules folder of the older versions (4.92.4) (Not correctly, but works). But doesn't work in modern versions ("Device not started").
My hardware works correctly in others softwares but not ProgDVB. Please, correct this in future versions!!
  • Sun Aug 16, 2015 12:03 am
Re: "BDA.device" (TDT) solution for ProgDVB modern versions
Please try last prerelase of ProgDVB.
  • Sun Aug 16, 2015 6:36 am
pascualet25
pascualet25
#3 by pascualet25
Same problem with pre-release. Fortunately it can be solved with the change of file. Thks.
  • Mon Aug 17, 2015 11:34 am
#4 by Prog
Can you send me logs of problem?
  • Mon Aug 17, 2015 3:30 pm
  • It is currently Mon Aug 24, 2026 5:03 pm
