ProgDVB and remote
Hi, i use ProgDVB with my TerraTec - Cinergy DT USB XS Diversity. That TV usb stick comes boundled with an useful remote, but i was able to use it only coupled with the TV program found in the bundle itself: DVBviewer (Terratec custom edition).
So the question is: what should i do to use that remote with ProgDVB (that is the only program i use ti see TV, as it is better in everything)?
In alternative, what can i do to use my Samsung Galaxy note 4 (with IR sensor) as remote with ProgDVB? Note 4 comes in bundle with the preinstalled app "Peel Smart remote" (but i can use also different apps).
Thanks in advance!
Re: ProgDVB and remote
Me too, but i'm not able to set custom remotes, and more, i wasn't able to use the IR remote. As sometime i experience some network issue, i wanted to use the IR remote (i think is a more stable and reliable connection).
And, of curse the TV card phisical remote (in bundle) would be the best solution, as it has all the key i need for all the function (included timeshift keys).
