In the download process explorer's warning.
serkanguzel
serkanguzel
Sat Nov 30, 2013 8:09 am
#1 by serkanguzel
Hi my master,
Last 2 version, this there are warning ;
Progdvb7.12.4a.Pro.exe corrupt and invalid signature.
The browser is used : Internet Explorer + Windows 8.1 enterprice 64 bit
Please fix.
Regards.
  • Wed Jan 20, 2016 10:20 am
Re: In the download process explorer's warning.
I have some reports but not have idea why. May be need some update of IE (root codes). You can download of ProgDVB and check sign in file properties. Sign is good.
  • Wed Jan 20, 2016 11:15 am
serkanguzel
serkanguzel
#3 by serkanguzel
Thanks for the response.
I check for updates now. But still the same.
I think it's time to pass Windows 10... So, Windows 10 + Edge Explorer.
Regards.
  • Wed Jan 20, 2016 1:03 pm
#4 by Prog
It is not reason for new OS :) You can still download ProgDVB.
  • Wed Jan 20, 2016 1:07 pm
serkanguzel
serkanguzel
#5 by serkanguzel
Yes master,
I install, now. ( Progdvb7.12.4a.Pro.exe )
Everything is working normally. :)
At least, we have confirmed that the problem not file.
Best regards.
  • Wed Jan 20, 2016 1:15 pm
#6 by Prog
Please try prerelease and report me
http://www.progdvb.com/download_progdvb_prerelease.html
  • Sat Jan 23, 2016 4:56 am
#7 by Prog
And final fix in .5 release. I hope no more problem.
  • Sat Jan 23, 2016 10:14 am
serkanguzel
serkanguzel
#8 by serkanguzel
Yes, my master.
No problem, with last version. ( ProgDVB Pro 7.12.5 )
Thank you, your effort.
Best regards.
  • Sat Jan 23, 2016 3:10 pm
  • It is currently Mon Aug 24, 2026 12:37 pm
