I get a signal but scan transponder and channel search show nothing.
Any ideas?
No DVB card ? ? ?
Driver?
Codec(s) used?
Settings / options? Like timeshift related f.e.?
How about the original software or other DVB applications?
L / Q, bird(s) /position(s)
Recordings also showing symptoms? If so, on which player(s)?
Checked those in PVAStrumento, f.e.? Error messages then?
Full relevant details, please.
Magic crystal ball out for polishing ATM, sorry...
Driver?
Codec(s) used?
I have a skystar2 card.SiLencer wrote:No DVB card ? ? ?
Driver?
Codec(s) used?
SkyNet.sys 4.3.0
SkyDll,Sky2pcui,a/v filter, 4.4.0
Sat AMC3
ProgDVd ver 4.82.1
I'm using a setup top box to check all my transponder setting.
Use only original driver from technisat ..best is 4.40 atm ...
About up to date transponder lists : viewtopic.php?t=27
copy to \progdvb\transponders
choose it in diseqC settings and make a scan...
Yep, that did the trick the 4.3 driver caused the problem thanx!SiLencer wrote:Use only original driver from technisat ..best is 4.40 atm ...
Thank'a lot, I had the same problem of no scanning and it solves with the 4.40 Skynet.sys driver. The distribution was in 4.3 driver.wildeye wrote:Yep, that did the trick the 4.3 driver caused the problem thanx!SiLencer wrote:Use only original driver from technisat ..best is 4.40 atm ...
