uninstall ProgDVB
hi, the program use cpu very high only with 6 channels opened.
before i had 6-8 channels opened and cpu usage was maybe 50%.
i want to format my pc and install a fresh copy of windows 10 and
after i see what do your program, but i need time to do this.
right now i want uninstall totally the program.
i know, i must go inside control panel, add-remove programs, etc.
but i want remove all keys inside the windows register (regedit).
what are the voices i must remove for install again another copy of progdvb ???
i'm sure when has crash, some files are missed and now my cpu work hard.
thank.
