- ProgDVB version: see attachment "Programm Version"
- DVB card type: Cinergy DT USB XS Diversity Digital Tuner
- Win7 Pro x64 english
- error messages: see attachment "Error Message"
- did a cold reboot help: no
Description: Time Shift buffer size less 4096 MBytes works fine. 4096MBytes seems to be interpreted as 0MBytes..
I tried 6144MBytes with the hope to gain more time at time shift buffer but it seems te became less buffer space. I notice this some days later and tried 8192 with the "Error Message" but though it is a memory resource problem, but normaly 10GBytes are free. So I reduced the buffer size and have the same result with 4096MBytes...
Hoppefully it is only 32Bit variable problem so may time at time shift buffer will grow in future.
Re: Time Shift Buffer 4GByte limit
#2But what size of physical memory? ProgDVB x64 not have limits.
#3Total physical memory 16GB.
9GB free + 4GB Time shift buffer in use.
Because I assumed there is no limit, I use the x64 version, but it seems one component have a limit.
#4Please send me logs after this error. No problem on my PC with 5000 and 6000 value(8gb memory)
#6The new version 7.13.02b seems to work with 4096MBytes and 8192MBytes. It takes some time now to fill time shift buffer. I added no longer required but requested logs.
Thanks
Thanks
- ProgDVB_7.13.02b_Logs_12052016b.7z
- Log without error if ts is set to 4096MBytes v7.13.02b
- (7.01 KiB) Downloaded 219 times
- ProgDVB_7.13.02__Logs_12052016.7z
- Log with error if ts 4096MBytes v7.13.02
- (6.33 KiB) Downloaded 210 times
