hi, my progdvb is started without the main interface.
i see that i workk because my cpu is busy 30-45% and in
the task manager i can see this process on:
NETSCHEDULERSERVICE(32 BIT)
my question is:
if now i want to scheduler some channels,
how i can do ???
i have tr to click on the progdvb icon, but i see a little panel
and 2 choices:
close uiprogdvb
and
stop record
i click the x on the up side and the program continue like before.
it is another button to click or inside the progdvb folder ???
thank very much.
Re: how to scheduler ???
#2That mean you schedule some record in this time. Impossible update task list before finish of recording.
ps: You can try other mode of scheduler.
