I am using ProgTV to play channels from an m3u file. Sometimes while watching a channel it will skip back 3 to 5 seconds repeatedly at about the same point. Then it will play for another 20 seconds and the skipping back happens again. I have tried changing the values for the buffering and enabling/disabling the timeshift mode but it doesn’t seem to help at those times. When I reload the channels it works ok but starts skipping back after a while.
Does anyone has any suggestions to avoid this?
Thank you all..
Re: Skipping back during playback
#2Looks like bug of ProgTV with HLS. Can you give me link to this channel?
#3It does not happen to a specific channel, but here are the last ones.
- CANALES.zip
- (400 Bytes) Downloaded 410 times
#4I am not can repeat this problem but try 2.20 version. Many changes in network and playback code.
#5Was there ever a solution to this problem. Its constantly happening me on lots of channels?
#6In last version? Please send me link on channel. I can try on next week.
#7hey my name is michael
and i'm using the progTv beta for a while
this problem constintly happens to me on variuos channels
after watching a movie(720p broadcast), it can happen after 10 min or after an hour
does not happen on regular iptv channels(sd broadcast)
tried to disable timeshift but no good.
any chance it has a network problam?
#8Repeats or skip some traffic? It possible bug of progtv or some server/network problem. Send me logs
#9Repeats itself constantly, a second before it happens, i get a massage about connection lost, trying to connect, taking to long, and then the movie repeats it self.
Will enable log and post.
