Re: PIP crash
#3the program is using ~320 mb, i've 6gb of ramProg wrote:Please send me logs.
ps: Check size of memory using of ProgDVB in task manager.
- Logs.rar
- (17.81 KiB) Downloaded 162 times
Re: PIP crash
#4This version very old. And plugin API not support of PIP. try without plugins at first.
Re: PIP crash
#5i know, when the problem happened i downgraded to this version in case of the problem was from the newer one.Prog wrote:This version very old. And plugin API not support of PIP. try without plugins at first.
anyway thank you! the plugin is the problem i tried without it and it works just fine.
Re: PIP crash
#6You can try change plugin. But in any case I am not recomend use more one plugin in same time.
