by greentea
Progdvb crashes when I try enabling 2 tuners in the options. Is it possible to run 2 installs of probdvb and have 1 tuner selected on each install? With other dvb apps I'm able to copy the install directory to another location and then run 2 copies of the app. Not sure prog can do the same as it looks like it has some folders outside of the install directory in c:\users\user\app data\local\progdvb.
