Hello Andrey,
I need your advice regarding FloppyDTV DVB-S2
Will it work properly with ProgDVB latest version?
Best regards.
Thank you for replying,Prog wrote:You can test and report meIt is BDA driver?
5.12.4 Add rolloff and pilot parameters to transponder list,support CI for FireDTV/FloppyDTV boxs.
5.12.3 Support Diseq and DVB-S2 for FireDTV/FloppyDTV boxs, support diseq for Terratec products, CI for technotrend 3650 box, fix skystar2 bug and some other improvements.
The problem is i'm still thinking whether i'll buy it or not, otherwise i would try it right away.Prog wrote:Do you try in modern version?
