madVR does not scale image
Hi!
I have a problem with latest ProgDVB and madVR renderer. I think pictures will show more than words:
It doesn't scale image correctly, well doesn't do it at all.
I have tried almost all the progDVB versions starting with 7.15.x.
Everytime it's the same. Looks exactly like in pictures. Upscaling and downscaling is broken.
I have updated GFX drivers and madVR to the latest versions: 0.91.5 in case of madVR but to no avail.
I'm using several apps which utilize madVR in my system and in every one of them madVR works perfectly. Except progdvb.
Am I missed something in the settings? Please help.
Logs after restarting and several changes of program window size.
(11.1 KiB) Downloaded 171 times
Re: madVR does not scale image
Prog wrote:I am not test madVR very long time. May be this problem with new madVR? Do you try old version?
0.91.5 ?
Now I understand why you put ? sign .
I've copied madVR over the previous version but not run setup.bat
My fault. 0.91.5 scaling correctly.
But for some reason this madVR version is not able to detect interlaced input. I had to "disable automatic source type detection" and enable "force video mode" to make it work. It seems I have to experiment with older versions :? .
