So I have ProgDBD Pro working on my PC and did an export of my settings. In there are my channel lists and EPG urls with passwords.
I transferred the export folder to my FIRESTICK. I can see the files there on the TV if I explore.
I then start ProgDVD on my TV via Firestick and go to OPTIONS ->EXPORT and IMPORT and then click IMPORT but nothing happens.
How do I IMPORT?
Re: Android - How to import settings
#3Selecting FOLDER does nothing. Nevermind - I entered it manually.
#4You must select folder and push on "import". What folder you select?
