Hi,
I just tried 6.60.4 version. I was using 6.40.4. I have the two versions in different directories.
I have Twinhan clone (Skystar 1-CI) DVB-S PCI. It is BT878 with CI slot. I use the 1.2.3.8 WHQL DVB-TV BDA drivers from the DigTV install in Win XP SP3 + .NET 3.5
I have 4 dishes connected to a single 4-port disecq switch.
In 6.60.4, I can't get any signal from anything other than the first dish - so it looks like Disecq isn't working. I use the same settings as before.
version 6.40.4 can see all 4 dishes OK.
what's the difference ? how do I get disecq working in 6.60.4 ?
best,
