v6.72.06 problem with mpg recording
Hi Prog,
i updated to v6.72.06 (Pro) x64, but there is still a problem with mpg recording. I don't know how to discribe this problem...
You should see it if you open a recorded (.mpg) file with VLC-Player. But I don't think it's a problem of VlC-Player because other mpg-files work fine.
So please check this out. Thanx :-)
Re: v6.72.06 problem with mpg recording
Prog wrote:But ProgDVB have bug with mpg in 6.72.5. Are you sure about version of ProgDVB?
Yes i'm sure about version it's v6.72.6. But i have this problem since a long time. same problem with v6.70.6. i only updated, because you have written "Fixes of mpg recording", so i hoped it was fixed. :(
Prog wrote:Every software have self mpg specific :(
You are right there but i tested different mpeg-files and there is no problem.
recorded by DVBViewer 4.9 -> no problem
recorded by DVB Dream 1.5g -> no problem
recorded by ProgDVB 6.7x as MPEG-TS (.ts) -> no problem
recorded by ProgDVB 6.7x as MPEG Video (.mpg) -> video problem*
*the audio stream works, but the video stream is corrupted.
i have to demuxe the video (PVAStrumento) and muxing again.
after that i can play with VLC-Player.
