I use since couple of years progdvb and I have since couple of years Hauppage Nova-S Plus. I used it before with ProgDVB but since 2 years I have 2 Sat positions over DiSEqC and ProgDVB doesn't work with DiSEqC and Nova-S Plus. The only solution for me was/is DVBViewer, which works very well, but miss a lot of things since I had to change to dvbviewer. On this forum is already one thread about it, but Prog never answered.
@Prog
Do you plan to to add DiSEqC support for Hauppage Nova-S Plus? I know you are very busy, but I hope to get answer.
greets
