Re: Skystar USB HD and remote control
#4I guess there is no support here. Why this forum exist at all?
#5First of all, this board exists, to allow people helping each other.
This is not a 24/7 service helpdesk.
Does your remote work with the original application, that came with your hardware?
Did you try relevant device settings in ProgDVB?
In the end, I don't have that tuner. So I can't really help. Anyone else to continue, perhaps?
#6Thanks for your reply. I've tried with the original application on my cd (DvbViewer TE) and its working perfectly.
On interface menu(ProgDvb) there are two control modules Universal HID remote control and Winlirc client. I've tried every combination in options menu from Universal HID remote control but its not working.
@Juergen are you using remote control and if you are on what device, it might help?
#7Yes I am.
But right now only for the Nexus, and this is a proprietary solution, not to be compared to anything else. So no, it will not help.
- fin -
- fin -
#9Its a small remote control that comes with Skystar USB HD. I can not find any picture of it , but I can take a picture tomorrow if it helps.
#11I can not understand. Is it plugin and if it is how can i put in ProgDvb?
#12hi everyone,  is anyone found how to use remote control from skystar usb hd in progdvb ?
#13Hi, looking for long hours, I've found nothing, and I hope now that you can help me further.
Namely the following:
I have a Technisat SkyStar USB HD, everything goes perfectly, I get not only the remote control to work.
The TV card has a built-in infrared receiver but he will not see me in ProgDVB.
Have no idea what to do yet to get the remote control to run.
Hopefully someone knows what I can do even
Speed
Speed
#14Lots of report about this problem. But I am not have information about API of RC for this device
#15Hi all. I also bought this product http://www.technisat.com/en_XX/SkyStar- ... 563456759/
Includes a remote FBPC100A/01. Went through all the options in ProgDVB, but could not get it to work. At this point the remote only works DvbViewer TE. And it is activated in the settings option. Remote receiver is part of the device.
What else can try to start using the remote control in ProgDVB?
