TechnoTrend Budget C-1501 Remote Control
Hey guys,
I just bought the TechnoTrend Budget C-1501 DVB-C Pci-Card and because I wasn't satisifed with the TT-Viewer I switched over to ProgDVB.
I was able to search for channels, configure my channel list, but I failed to get my Remote Control to work.
I tried to go Settings -> Options -> Controls and chose the {BDA} TechnoTrend BDA/DVB-C Tuner module, but ProgDVB doesnt react do anything I do with the remote control.
The remote Control works fine with the TT-Viewer though.
Can you help me?
cheers, coopaaa
