Hi all,
I want to write a plugin, but I cannot find any source code in C/C++.
Does anybody knows a plugin that its source code is available?
Is there a "sample" plugin I can see?
I am interested in the initialisation code of the plugin, so as a dll can be loaded by progDVB.
I have found some sources here, but in .NET (C#):
http://attaboy.ru/osh/files/default.aspx
http://attaboy.ru/osh/files/422/download.aspx
From a plugin named OSH (On Screen HTML).
It was easy after all. A simple DLL with some special named exported function
But still a sample plugin/tutorial would be nice...
