Re: plz help long time watting
do u mean this manual ??
http://www.progdvb.com/manual2/options_modules.html
yes i read
but ther is nothing to how to install-use-register: prog media server pro
Now it is work in same time in 1 PC in part C and part D
Work 100%%%%
Plz iwant help here:
1-I have original Prog Media Server v3.68 pro
2-But I don not know wher should I install this program
In Same my pc or in the client pc?
3-Shold I install the progdvb standard in the other client pc or install prg media client pro?
4-I have the activation code for prog media server pro but I don not know where should I but the active code???i mean how to register??
5-How can I change prog media server(home) here to prog media server pro
Because I have prg media server pro but I do not know wher should I install also in which part of my pc ?
thankxx
2. You should install Server on server PC :)
3. You can use standart ProgDVB Pro on client.
4. In registration dialog of Prog Media Server Pro (not same key with ProgDVB Pro)
5. Install over ProgDVB. You can look module version in Service->Prog Media Server in ProgDVB.
