IPTV in denmark
Hello forum.
I am using a Kreatel 1510 in order to view IPTV from danish DanskBredbånd (Dongenergy as the underlying fiber provider)
Anybody knows the multicast UDP settings my IPTV provider is using?
..or maybe a way for me to find out for myself?
Benny
Yeah, I thought so.
When you do this blind search, the port is predefined, yes? e.g.5000
..or does it scan ports as well?
I just wish there some kind of listing of the different providers UDP broadcasting preferences.
yes, i know.
I've tried them, but apparently the danish providers use other IP's or ports.
Maybe another approach would be to explore the Kreatel 1510. The USB port could be the way to communicate with the TV-box and snatch some configuration file content.
..but if possible at all, its propably not the simpliest task to do.
PS. BTW Prog, I am very pleased that you are responding, if you dont know, I guess nobody knows :-)
Thats quite ok, you cant be all over the world :-)
How was the listings of the russian providers retrieved?
...inside information? ..or network analysis?
ah ok..
Well, it's a bit secret here in the west, I allways thought it was the other way around :-)
..maybe wireshark or something can help me.
Anyway, Prog, thanx very much for your help
Benny
