i just wanna post this problem and i hope to get it fix by devs in android progdvb
first of all the progdvb android is the best app i ever used ! i try all apps but there is no app like progdvb apk
on my samsung galaxy s6 runs like magic
but he got some problems need to fix and here is a list
Problem 1 - ( when i the channels playing then time out to server progdvb stops and say Retry connection in red )
Fix - ( the app should have autoretry to keep app retrying to connect all the time non stop) and we should have option to enable autoretry
Problem 2 - ( Screen Lock ) when i playing a channels i allways accedently hit volume or change channels accedently
Fix - ( we need lock screen )
Problem 3 - ( Rotate screen . when i rotate my phone horizontal to vertical the app stops and start buffering from beginning
Fix - ( we need fix for that )
Problem 4 - ( when app is closed and the shortcut still in task bar when i hit the short cut the app crash )
Fix - ( app should start if close or open )
and last we need more codecs on it...
well this is what i want to be added on this app and its awsome app anyway thatnkyou all for Great updates on Prog dvb for pc and android .
