I just installed vista and i am trying to run progdvb.
The driver for my cards was provided by windows update but when i run progdvb it says that it cant start the device.
It might be a driver issue.
My card is DVB-TV 878.
Is there any issues with the windows drivers or the problem is with in progdvb.
If someone can help plz let me know.
Regards
i did use the search option dude, there was nothing there that could help me though.
so basically this is my problem. Look at the picture
Is this a problem with in probdvb or the driver??
I don´t use Windows Vista (exellent Spyware
and i don´t know your card ? which manufacturer ?
and you don´t say what kind of drivers you are using ? BDA or WDM ...
i got no idea which driver is it. It came from windows update.
Check the picture below. If u notice the second file on the right it says BDAsup.sys so i guess it should be the BDA but i cant be 100% sure.
You know where can i get drivers for vista?
I tried that but it gives more errors
It keeps crashing dvbprog. I am guessing i am using the correct device, i mean that the one i use in winxp.
Any other ideas?
Any other ideas?
some problem in windows vista
#10not work with Nero-7.5.9.0A
not work with Bluetooth
not work with any antivirus
some problem in IE7
not work good with Windows Media Player for moves
not work good with codec K-lite
not work with Alcohol 120% and all Virtual CD
after some time the computer is stop
very very bad windows
some problem in IE7
well basically vista are not suppost to be out yet
I guess we need to wait for drivers.
The only problem is, are the hardware companies planning to release drivers for vista? Thats my main concern......
windows vista is new operating systemSteelBlade wrote:well basically vista are not suppost to be out yet
need some time to discovery the problem in windows and fix it
and all program suport 100 % without problem after some time
work 100 % after SP1 and SP2
