Prog wrote:2. Please give me more details. No any problem on my PC. Try select other files. May be some differents...
3. Too many changes. Impossible install old version over new. But new version must import old list and configs without problems.
2.details about cut & delete problem ? what other information you need tell me i will help. also i can give you Team Viewer ID to check and test your self. for that be in contact with my yahoo messenger id :
FTA_Boy@yahoo.com
on new version i cant delete and cut channels , right click on a channel and select Delete, will do nothing at all.
3.new version of progdvb import old channel list and config but the problem is after a manual scan founded channels will add to list again but i have them in the list before (from old version list.)
here is a part of log , i'm watching a channel with name "4" meanwhile i try to attempt to delete a channel with name "4Fun.TV" using right click on "4Fun.TV" from opened menu click Delete:
16:47:54.979 -
16:47:54.980 -
16:47:54.980 - ########################### Mark of start channel changing.###########################
16:47:54.980 -
16:47:54.980 - GraphManager::MainChangeChannel 4
16:47:54.981 - DevicesManager::DestroyAllTransponderManagerUsedForSetTransponders
16:47:54.981 - CSetChannelLogic::SetChannel 0
16:47:54.981 - CSetChannelLogic::SetNormalChannel
16:47:54.981 - ChannelGraph5::StopChannel 4
16:47:54.981 - TimeShift::Cursor PushMode 0 0 (0)
16:47:54.982 - ReaderCursor::SetPosition 0 (w=80207380)
16:47:54.982 - Prereader::EnablePushModeAndStartPlayback 0
16:47:54.982 - CPreScanner::Stop
16:47:54.982 - PlayTimePmtParser::StopParser
16:47:54.983 - CSubtitlesPrsersManager::StopChannel
16:47:54.983 - Graph::Stop
16:47:54.998 - Graph::ReleaseAllFilters
16:47:54.999 - release: Prog Audio renderer - RR - OK.
16:47:55.071 - release: Video Renderer - RR - OK.
16:47:55.074 - release: MainConcept MPEG-2 Video Decoder - RR - OK.
16:47:55.078 - release: Audio Processor - RR - OK.
16:47:55.079 - release: MainConcept Layer II Audio Decoder - RR - OK.
16:47:55.080 - FilterGraph: 1
16:47:55.080 -
16:47:55.081 - TransponderManager::SetTransponder (CH) 11054000 4
16:47:55.081 - Api2Device::SetChannel 11054000Khz sid=8044
16:47:55.081 - ch:4 {freq:11054, pol:H, sr:27500}
16:47:55.500 - Api2Device::SetChannel result OK
16:47:55.500 - TsInputTrafficProcessor::OpenTransponder 1
16:47:55.500 - FilterManager::OnSetTransponder SetChannel
16:47:55.500 - TimeShift::Reset
16:47:55.501 - TimeShift::Cursor reset
16:47:55.502 - Prereader::Reset
16:47:55.502 - ModuleList::ChangeChannel 11054000
16:47:55.503 - DvbEpgParser::SetChannel 11054000
16:47:55.504 - CChannelGraph5::StartChannel 4
16:47:55.504 -
16:47:55.505 - #################### Start stream. (0.514ms) #######################
16:47:55.505 -
16:47:55.507 - TimeShift::Cursor SetChannel
16:47:55.507 - ReaderCursor::SetPosition 0 (w=0)
16:47:55.508 - Prereader::SetChannel unmask 1
16:47:55.508 - Plugin::SetChannel 8044
16:47:55.509 - TransponderManager::SelectChannel
16:47:55.509 - TsInputTrafficProcessor::SelectChannel 8044
16:47:55.509 - Api2BaseModule::UpdateAllOpenedChannels 1
16:47:55.509 - TsInputTrafficProcessor::UpdateChannel 8044
16:47:55.510 - PreScanner::StartChannelIsReady
16:47:55.510 - ChannelGraph5::AfterDetectChannelParams
16:47:55.510 - VideoMediaTypeDetection: mpeg2
16:47:55.510 - SimpleTsDemux::Init apid=4420, vpid=4410
16:47:55.510 - TimeShift::Cursor PushMode 1 1 (0)
16:47:55.511 - ReaderCursor::SetPosition 0 (w=0)
16:47:55.511 - Prereader::EnablePushModeAndStartPlayback 1
16:47:55.511 - PreScanner::StartPmtParserIfNeed
16:47:55.511 - PlayTimePmtParser::OpenParser 8044
16:47:55.511 - Graph::UpdateRenderMode
16:47:55.512 - Graph::SetVideoRect {8 8 712 568}
16:47:55.512 - Graph::SetVideoWindowRect {78 0 1056 734}
16:47:55.512 - ChannelGraph5::SetActiveState 1
16:47:55.530 - * s:43 q:37 tr=-80407036 (0)
16:47:55.550 - First data in TS buffer
16:47:55.590 - AudioParser::First packet 1440
16:47:55.590 - AudioParser::MPG12 detected
16:47:55.590 - VideoParser::First packet 16336 mpeg2
16:47:55.620 - VideoParser::packet 26536
16:47:55.700 - VideoParser::packet 54868
16:47:55.720 - VideoParser::packet 63632
16:47:55.750 - VideoParser::packet 72864
16:47:55.769 - VideoParser::packet 80748
16:47:55.850 - VideoParser::packet 105608
16:47:55.870 - VideoParser::packet 113228
16:47:55.890 - VideoParser::packet 121408
16:47:55.910 - VideoParser::packet 127512
16:47:55.980 - VideoParser::packet 152400
16:47:55.990 - VideoParser::packet 154996
16:47:56.020 - VideoParser::packet 163456
16:47:56.040 - VideoParser::packet 170072
16:47:56.100 - VideoParser::packet 190532
16:47:56.120 - VideoParser::packet 198048
16:47:56.149 - VideoParser::packet 208220
16:47:56.171 - VideoParser::packet 215384
16:47:56.220 - VideoParser::packet 233568
16:47:56.240 - VideoParser::packet 241172
16:47:56.270 - VideoParser::packet 249496
16:47:56.289 - VideoParser::packet 257480
16:47:56.350 - VideoParser::packet 278768
16:47:56.380 - VideoParser::packet 289056
16:47:56.410 - VideoParser::packet 299808
16:47:56.440 - VideoParser::packet 307432
16:47:56.480 - VideoParser::packet 323700
16:47:56.510 - VideoParser::packet 332684
16:47:56.550 - VideoParser::packet 346304
16:47:56.580 - VideoParser::packet 357196
16:47:56.629 - VideoParser::packet 373200
16:47:56.660 - VideoParser::packet 382368
16:47:56.690 - VideoParser::packet 393564
16:47:56.710 - VideoParser::packet 401448
16:47:56.760 - VideoParser::packet 417088
16:47:56.769 - VideoParser::packet 420600
16:47:56.773 - * s:43 q:36 tr=477708 (6768)
16:47:56.810 - VideoParser::packet 433672
16:47:56.830 - VideoParser::packet 443160
16:47:56.890 - VideoParser::packet 461408
16:47:56.920 - VideoParser::packet 474248
16:47:56.950 - VideoParser::packet 484020
16:47:56.980 - VideoParser::packet 494484
16:47:57.080 - VideoParser::packet 528872
16:47:57.081 - VideoParser::mpeg2::Sequence header detected!
16:47:57.082 - PreScanner::Post_InitRender
16:47:57.082 - ChannelGraph5::uiThread_CreateGraphAfterDetectOfMediaTypes
16:47:57.082 - TimeShift::Cursor PushMode 2 0 (0)
16:47:57.082 - ReaderCursor::SetPosition 0 (w=592952)
16:47:57.082 - Prereader::EnablePushModeAndStartPlayback 2
16:47:57.083 - ChannelGraph5::CreateInterfacesAndRenderGraph
16:47:57.084 - CSubtitlesPrsersManager::StartChannel
16:47:57.084 - CChannelGraph5::HideSubtitles
16:47:57.085 - CreateCustomGraph
16:47:57.085 - VideoType:MPEG2
16:47:57.085 - Video/MPEG2_VIDEO : MPEG2_VIDEO s={0,0,720,576}, t={0,0,720,576}, bmp=720x576, r=4/3, br=15305200,frametime=40ms, IF=0x0, CF=0x0)
16:47:57.087 - Add video codec bc4eb321-771f-4e9f-af67-37c631eca106 - OK
16:47:57.087 - CChannelGraph5::CreateRender 10
16:47:57.087 - VR: EVR Custom
16:47:57.128 - Add video Post process. Result: Pin for connection not found! 0x80040207
16:47:57.132 - Add video renderer Video Renderer - OK
16:47:57.132 - СreateAudioPartOfGraph
16:47:57.132 - AudioType:MPG
16:47:57.132 - Audio/MPEG1AudioPayload : WaveFormatEx (2ch 48000 0bit formatTag= 0x50)
16:47:57.133 - Add audio codec 2f75e451-a88c-4939-bfe5-d92d48c102f2 - OK
16:47:57.164 - IMyGraphBuilder::CreateAudioRenderFilter::ProgAR:Primary Sound Driver OK
16:47:57.165 - Added audio processor
16:47:57.168 - AudioProcessor: Audio - {00000001-0000-0010-8000-00AA00389B71} - PCM - :CheckMediaType in MediaType (OK) 2ch, 16bits, 48000 samples
16:47:57.168 - AudioProcessor: Audio - {00000001-0000-0010-8000-00AA00389B71} - PCM - :Set in MediaType (OK) 2ch, 16bits, 48000 samples
16:47:57.169 - Connect codec to AP - OK
16:47:57.169 - AudioProcessor: Audio - {00000001-0000-0010-8000-00AA00389B71} - IEEE_FLOAT - :CheckMediaType in MediaType (FAILED) 2ch, 64bits, 48000 samples
16:47:57.169 - AudioProcessor: Audio - {00000001-0000-0010-8000-00AA00389B71} - IEEE_FLOAT - :CheckMediaType in MediaType (FAILED) 2ch, 32bits, 48000 samples
16:47:57.169 - AudioProcessor: Audio - {00000001-0000-0010-8000-00AA00389B71} - PCM - :CheckMediaType in MediaType (FAILED) 2ch, 32bits, 48000 samples
16:47:57.176 - Add and connect audio renderer - OK
16:47:57.177 - Graph::AfterRender
16:47:57.177 - Graph::SetVolume 33% -1999db
16:47:57.178 - Graph::SetAudioChannelMask
16:47:57.178 - AudioProcessor::SetAudioChannelsMask
16:47:57.178 - AudioProcessor::SetEqualizerBands
16:47:57.179 - AudioProcessor::EnableSpectrum
16:47:57.179 - AudioProcessor::AgcEnable
16:47:57.179 - Graph::Run
16:47:57.198 - Graph::Run 1
16:47:57.199 - Graph::SetPictureParams
16:47:57.199 - Graph::SetVideoRect {8 8 712 568}
16:47:57.199 - Graph::SetVideoWindowRect {78 0 1056 734}
16:47:57.199 - AfterRenderInit
16:47:57.257 -
16:47:57.257 - ########################### Mark of finish channel changing. (2.277ms) #############
16:47:57.258 -
16:47:57.293 -
16:47:57.293 - ########################### First video frame. (2.308ms) #############
16:47:57.293 -
16:47:57.787 - * s:43 q:36 tr=372052 (564)
16:47:58.802 - * s:43 q:37 tr=380888 (0)
16:47:59.815 - * s:43 q:37 tr=384460 (0)
16:48:00.830 - * s:43 q:36 tr=380700 (0)
16:48:01.844 - * s:43 q:36 tr=380136 (0)
16:48:02.857 - * s:43 q:37 tr=380700 (0)
16:48:03.871 - * s:43 q:37 tr=384272 (0)
16:48:04.887 - * s:43 q:36 tr=380324 (0)
16:48:05.901 - * s:43 q:37 tr=384460 (0)
16:48:06.914 - * s:43 q:36 tr=361712 (376)
16:48:07.928 - * s:43 q:37 tr=380700 (0)
16:48:08.942 - * s:43 q:37 tr=369232 (0)
16:48:09.955 - * s:43 q:37 tr=391416 (0)
16:48:10.970 - * s:43 q:37 tr=388220 (0)
16:48:11.984 - * s:43 q:37 tr=380324 (0)
16:48:12.998 - * s:43 q:37 tr=384460 (0)
16:48:14.012 - * s:43 q:37 tr=377692 (188)
16:48:15.025 - * s:43 q:37 tr=380512 (0)
16:48:16.040 - * s:43 q:36 tr=383896 (0)
16:48:17.053 - * s:43 q:36 tr=380700 (0)
16:48:18.068 - * s:43 q:36 tr=380512 (0)
16:48:19.097 - * s:43 q:37 tr=391980 (0)
16:48:20.111 - * s:43 q:37 tr=380136 (0)
16:48:21.125 - * s:43 q:36 tr=384836 (0)
16:48:22.139 - * s:43 q:36 tr=353252 (376)
16:48:23.153 - * s:43 q:37 tr=380700 (0)
16:48:24.167 - * s:43 q:37 tr=380324 (0)
16:48:25.181 - * s:43 q:37 tr=378632 (188)
16:48:26.200 - * s:43 q:36 tr=380324 (0)
16:48:27.209 - * s:43 q:36 tr=384460 (0)
16:48:28.223 - * s:43 q:36 tr=380324 (0)
16:48:29.237 - * s:43 q:37 tr=380888 (0)
16:48:30.251 - * s:43 q:37 tr=379008 (376)
16:48:31.264 - * s:43 q:36 tr=372428 (188)
16:48:32.278 - * s:43 q:36 tr=379008 (0)
16:48:33.292 - * s:43 q:36 tr=382956 (0)
16:48:34.306 - * s:43 q:37 tr=380512 (0)
16:48:35.320 - * s:43 q:36 tr=384272 (0)
16:48:36.334 - * s:43 q:37 tr=376000 (0)
16:48:37.349 - * s:43 q:37 tr=381264 (0)
16:48:38.363 - * s:43 q:37 tr=378444 (0)
16:48:39.377 - * s:43 q:36 tr=380512 (0)
16:48:40.391 - * s:43 q:37 tr=384460 (0)
16:48:41.408 - * s:43 q:36 tr=380512 (0)
16:48:42.419 - * s:43 q:36 tr=380512 (0)
16:48:43.433 - * s:43 q:36 tr=380512 (0)
16:48:44.450 - * s:43 q:37 tr=376564 (0)
16:48:45.461 - * s:43 q:37 tr=380324 (0)
16:48:46.475 - * s:43 q:37 tr=380888 (0)
16:48:47.489 - * s:43 q:37 tr=384084 (0)
16:48:48.506 - * s:43 q:37 tr=380700 (0)
16:48:49.517 - * s:43 q:36 tr=380512 (0)
16:48:50.234 - Graph::SetVideoWindowRect {0 0 0 0}
16:48:50.530 - * s:43 q:36 tr=384272 (0)
16:48:51.544 - * s:43 q:36 tr=381640 (0)
16:48:52.558 - * s:43 q:36 tr=380324 (0)
16:48:53.576 - * s:43 q:36 tr=380512 (0)
16:48:54.587 - * s:43 q:37 tr=388220 (0)
16:48:55.362 - Graph::SetVideoWindowRect {78 0 1056 734}
16:48:55.606 - * s:43 q:37 tr=380512 (0)
16:48:56.620 - * s:43 q:36 tr=380700 (0)
16:48:57.633 - * s:43 q:37 tr=368668 (0)
16:48:58.643 - * s:43 q:36 tr=379760 (376)
16:48:59.658 - * s:43 q:37 tr=375248 (188)
16:49:00.672 - * s:43 q:37 tr=380700 (0)
16:49:01.685 - * s:43 q:37 tr=380512 (0)
16:49:02.704 - * s:43 q:35 tr=380700 (0)
16:49:03.714 - * s:43 q:35 tr=383896 (0)
16:49:04.735 - * s:43 q:36 tr=377128 (0)
16:49:05.742 - * s:43 q:36 tr=384084 (0)
16:49:06.758 - * s:43 q:36 tr=388032 (0)
16:49:07.769 - * s:43 q:36 tr=380512 (0)
16:49:08.783 - * s:43 q:36 tr=376752 (188)
16:49:08.931 -
16:49:08.932 -
16:49:08.932 - ########################### Mark of start channel changing.###########################
16:49:08.932 -
16:49:08.932 - GraphManager::MainChangeChannel 4fun.TV
16:49:08.932 - DevicesManager::DestroyAllTransponderManagerUsedForSetTransponders
16:49:08.933 - CSetChannelLogic::SetChannel 1
16:49:08.933 - CSetChannelLogic::SetChildChannel
16:49:09.804 - * s:43 q:36 tr=388032 (0)
16:49:10.816 - * s:43 q:37 tr=374684 (0)
16:49:11.826 - * s:43 q:36 tr=376376 (0)
16:49:12.839 - * s:43 q:36 tr=380512 (0)
16:49:13.715 - Graph::SetVideoWindowRect {0 0 0 0}
16:49:13.854 - * s:43 q:37 tr=384084 (0)
16:49:14.870 - * s:43 q:36 tr=364908 (0)
16:49:15.882 - * s:43 q:36 tr=376752 (0)
16:49:16.900 - * s:43 q:36 tr=375436 (2820)
16:49:17.367 - Graph::SetVideoWindowRect {78 0 1056 734}
16:49:17.913 - * s:43 q:36 tr=376752 (188)
16:49:18.927 - * s:43 q:36 tr=380324 (0)
16:49:19.938 - * s:43 q:37 tr=384272 (0)
16:49:20.958 - * s:43 q:37 tr=376752 (0)
16:49:21.980 - * s:43 q:37 tr=388220 (0)
16:49:22.994 - * s:43 q:37 tr=384084 (0)
16:49:24.008 - * s:43 q:36 tr=384648 (0)
and nothing happen , only a ding sound from windows. 4Fun.TV
not delete..
same log when i click Cut :
16:55:14.604 - ########################### Mark of start channel changing.###########################
16:55:14.604 -
16:55:14.605 - GraphManager::MainChangeChannel 4fun.TV
16:55:14.605 - DevicesManager::DestroyAllTransponderManagerUsedForSetTransponders
16:55:14.605 - CSetChannelLogic::SetChannel 1
16:55:14.605 - CSetChannelLogic::SetChildChannel
