I do
not know if someone already posted this, but when I press Options the error occurs.
full message:
System.ArgumentException: An entry with the same
key already exists.
at System.Collections.Specialized.ListDictionary.Add(Object
key, Object value)
at ProgDvbEngine.AV.EnumLinesOnAllDevices(ValueType current)
at ProgDvbNet.AudioVideoSettingsForm.SetSettingOnForm()
at ProgDvbNet.AudioVideoSettingsForm.AudioVideoSettingsForm_Shown(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
ProgDvbNet
Assembly Version: 1.0.0.0
Win32 Version: 5.06
CodeBase: file:///C:/ProgDVB_5/ProgDvbNet.exe
EngineApiWrapper
Assembly Version: 1.0.2645.27013
Win32 Version:
CodeBase: file:///C:/ProgDVB_5/EngineApiWrapper.DLL
msvcm80
Assembly Version: 8.0.50608.0
Win32 Version: 8.00.50727.42
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd/msvcm80.dll
System
System.Drawing
IPDev.Skins
Win32 Version: 1.0.0.0
CodeBase: file:///C:/ProgDVB_5/IPDev.Skins.DLL
System.Xml
Accessibility
System.Design
System.Drawing.Design
enabled.
For example:
<configuration>
</configuration>
P.S. Im using skystar1 hardware mode
AMD athlon 1.8 GHz
1 GB RAM
GeForece FX 5500
