Hi,
The keyboard key "Esc" will not close popup "Acces Authentification" when it sometimes appears during a chain shift (IPTV). it worked well with ProgDVB_x86 7.28.2 ProgDVB _x86 7.30.2, but not since 7.31
Regards.
Re: Keyboard key "esc"
#3IPTV mode:
Try an url with authentification mismake, for example : http ://iptvpro.vision-new.org:8789/live/badlogin/badpwd/2566.m3u8
This brings up the popup.
When you don't want to fill in the fields and you want to close the popup to zap on another url, we could do it simply with the "Esc" key without having to click on "Cancel" with the mouse. It worked well with ProgDVB_x86 7.28.2 ProgDVB _x86 7.30.2, but not since 7.31
