#107
would it help if I changed the Directshow TV Channels to NVidea?
I have NVidea Geforce GO7600 Graficcard in the laptop.
#109
Being very new at this, could you please tell me how or send me a link to where the prob was discussed?SiLencer wrote:try it ...but i meant the video renderer settings...
Can not move Window
#111Hi !
I have a problem when ProgDVB 5.10.01 is not maximized, but a normal window. If I want to move the window by clicking on the title bar just as you move any other window, the window disappears quickly from the screen and is gone. Fullscreen and maximized works fine.
Mauswiesel
Mauswiesel
Not really a bug, but...
#112...It's a typo. Maybe/probably been picked up before by someone else.
In the right-click menu, in Navigation, "previous" is misspelled as "previuos".
#113
I'm using the Version 4.85.3 of Progdvb, but lately the programm seem to freeze and I need to start the programm again.
I had a look in the "Windows XP Task manager" and the only problem I can find is that Progdvb is occuping 19 % - 50 % of the CPU, whilst the rest of the CPU power is being occupied by the tickover programm (Leerlauf). I have tried changing the priority of the prog in the Task manager to high etc. but it still freezes.
Can anyone help?
Can anyone help?
#114
...not occuoied in any way. That's just idle state, not a programfrank666 wrote:...whilst the rest of the CPU power is being occupied by the tickover programm (Leerlauf).
There may be tons of possible reasons, like codec type and it's properties, renderer, but also plugins, VGA overlay or ~ memory issues (e.g. shared memory causing heavy extra bus load if not dual channel used, at least) and many more.I have tried changing the priority of the prog in the Task manager to high etc. but it still freezes.
Can anyone help?
First of all, try to 'disable MPEG2 decoder for low CPU use' and compare.
This may give a hint, where to start to look on...
#115
Where can I do that ? If you could answer in German it would help as my XP is in GermanJuergen wrote:[
First of all, try to 'disable MPEG2 decoder for low CPU use' [/b][/b]and compare.
#117
I want to know the real function of MPEG-2 Decoder in Timeshift buffer menu ?!
I mean that we use a Filters ( Elecard , Cyperlink .... ) from direct show in Progdvb , so what mpeg2 decoder do . what happen if we disable it ?!
I know that is silly question
#118
The Codecs only produces Video and Audio for Live TV ...thats all...and if you disable it ...no Video or Audio is present ...but records works still fine ...
#119
I meant the option " disable mpeg2 decoder for low cpu " not in generalSiLencer wrote:The Codecs only produces Video and Audio for Live TV ...thats all...and if you disable it ...no Video or Audio is present ...but records works still fine ...
