#1291
I still have some problematic H264/AAC channels, sometimes need two, three or more retunes to open them.
I did some more tests with recordings, and most of time VLC plays nice the content. A few times no audio with VLC.
With WMP I cant play AAC audio at all in progdvb records.
As Progdvb always plays those recordings, lets wait for insights to the root of problem :| .
Later will do recordings with other dvb players, to compare recordings, and tell you.
#1302
Serag4000 wrote:Hi,
I'm using 6.92.6.0 32bit, on Win8 64bit, and a USB DVB device.
Sadly I face lots of problems, including engine failure and hangs, which I can't confirm the source of, whether it is driver related, system related, or ProgDVB related. But, at the end of the day, I face lots of ProgDVB crashes.
Now, as of lately I started to notice that my Favorite list sometimes gets corrupted, with the channel being viewed before the crash just disappearing from the lit altogether !
It happened frequent enough, that I made a compressed copy of the "Channels" folder, that I use to overwrite the original after a crash.
One other Channel list related minor issue, is that sometimes after selecting a channel from the favorites list, then opening the list (using the RC button), I would find my self in the SAT list which had the channel in question, as opposed to remaining in the favorite list, until choosing another list.
In any case, Is there a way to make the channel lists more stable ?
Prog wrote:Please send me logs after Engine problem.
Channel list is quite stable. I am not have many reports from other users. You can try install ProgDVB to other directory and rescan channels again.
Well, apparently the easiest, and most straight forward, solution appeared to do the trick. Just installed in different location and no more Favorite list issues.
Thanks for helping out.
#1303
marec wrote:There´s no signal / quality in manual and full scanner dialogs, ver 6.93.
Caption says absent signal, but scan can find channels. This problem showed up some mounths ago, now back again :( .
Can confirm no signal/quality display in scanner dialogs of Prog 6.93/d.
Tested on XP/W7x86, Terratec PCI-HD/Technotrend CT-3650 CI/C-1501
#1304
The traditional AAC audio problems full returned with last version. "No conection AP to AAC" or something like this. A ridiculous warning says to change audio codec, but any codec is the same result. And serious audio to video unsync, too.
So, theres a wise rule to Progdvb: dont update if you have a working version... New versions means old unresolved problems and maybe some new ones...
