#1396
Prog wrote:I am recommend disable this option.
ok, Stability Mode unchecked but still have same problem. whole program will crash with not responding in progdvb windows. same log file...
#1398
Prog wrote:Same error in logs? Same without plugin?
yes same error, with plugin (Hadu.dll).
another error today. turned on the computer opened progdvb and immeadtly i see crash windows like picture i attached, restated and progdvb opened.
logs after this crash are attached too.
Update : WTF !! each time i open ProgDVB this crash windows will appear and after that recovery dialog will pop up ... going to install fresh copy
Update2 : installing again (update) didn't solve the problem. splash screen load complete and crash, restart progdvb , again splash screen load full , recovery window , now progdvb open and work (on every opening of ProgDVB this happen)
Update3 : selecting stability mode didn't solve this crash either.
Update4 : SOLVED, downgraded too old versions (using Update Old .... in setup file) and there was no problem. again installed ProgDVB6.96.0Pro (using update) problem of opening crash Solved ! but still have Cache overload (Incoming Stream Cache -5120000) !!! problem...
16:15:55.633 - Graph::OnWindowMove 102
16:15:55.634 - Graph::SetVideoWindowRect {96 0 1074 734}
16:15:55.639 - First data in TS buffer
16:15:56.046 - * s:43 q:47 tr=199092 (5828)
16:15:56.078 - !! TopLevelExceptionFilter !! Unknow/NON CONTINUABLE 1
16:15:56.079 - module: C:\Windows\system32\KERNELBASE.dll
16:15:56.079 - thread: 0x1238
crash
prev1.zip
Logs after the crash as you see in picture
(4.83 KiB) Downloaded 336 times
#1399
its happening again , each PC restart the crash windows will appear again. downgrade to 6.95.9 and again install 6.96 will fix the crash on opening progdvb until restart.... 6.95.9 is stable , but i like to use 6.96 because switching audio streams work in this version. trying to help
regards
#1401
babak0007 wrote:hi prog
stability mode doesn't work in last 3 version up until 6.96.1 . it doesn't mater if activated or not .progdvb doesn't automatically restart after crash. And when it crashes it just exits the progdvb and i haveto manually start it again
thx
Hi babak. yes i can confirm it, i already reported this problem to Prog. he is working on it. please use 6.96.1a (pre-release version) and after crash upload Logs folder here.
@Prog: yesterday i update to 6.96.1a but still no crash happened yet! if it happen i will give you logs too (as you requested in PM)
#1403
Prog wrote:I have too many bad reports about stability mode. Is it really help you?
ps: "a" prerelease have some improves and must be more stable.
from last night that i updated to 6.96.1 (a) pre-release NO crash happened, worked good until now :) hope all crash problems are fixed but if it happens again i will let you know.
what improvements have you done in this version? because i think it worked :)
#1408
hi again
no i cant say that i have it every time but some time it happens more and some times less mostly when im changing from one channel to another regardless of it being scrambled channel or not or when im recording from a scramled channel or some times when the frequency of whatched channel is week for bad weather or whatsoever this crash hapends.
and for your second question : i checked and the latest version that progdvb restart automatically after crash is 6.95.8 .but the most stable version that i have ever used is 6.96.1a. but unfortunately 6.96.1a doest restart after crash Even if stability is activated so stability mode doesn't work in last 3 version up until 6.96.1a .
thx.
