#1457new kind of crash happening, i think this happen after v7.03
time: 2.4.2014 12:9:11
Type: Crash in unmanaged part
Module: C:\Program Files\ProgDVB\ProgDvbNet.exe
Thread: 0x874 .WinLirc client
ProgDVB was open but winlirc.exe client wasn't running , opened a proxy program then closed Proxifer this crash happened (i think same will happen if i connect a vpn , not sure)
logs are attached.
edit: I'm sure this crash will happen if i exit the program called : Proxifer. and only will happen if winlirc.exe is not open.
logs are attached.
- prev1.rar
- Thread: 0x874 .WinLirc client
- (15.63 KiB) Downloaded 365 times
#1458hi dear prog, still have problem with switching channel from my dvb-s (skystar 2pci) too Internet TV or Torrent TV or reverse.
for example I'm watching a DVB-S channel and i go to torrent tv channel list and i select a channel but it wont switch to that channel. progdvb title will change to that channel name but at the bottom it wont change name , and still showing old dvb-s channel. see the picture attached . the only way its possible for me to watch a internet/torrent TV is to click on stop button then select torrent tv channel now it will change..., when a torrent tv is buffering or give a error stop button is disabled and i cant click stop button to back to dvb-s channel !! logs are attached . sorry for long post.
BTW Torrent TV is interesting!
thanks
#1459Try scan dvb channels again...
ps: Torrent TV is not free content...
#1460removed all my dvb channel list with , menu channel list > editor. then scanned again. still can't change channel to internet tv o torrent tv.Prog wrote:Try scan dvb channels again...
what do you mean torrent tv is not free i can watch theme using Ace Stream Media.
#1461Ace Stream Media account price ~10 euro in year. I am not sell then..
#1462currently it have a test account in it self and i read somewhere test account will work always but maybe have ads...Prog wrote:Ace Stream Media account price ~10 euro in year. I am not sell then..
BTW what about the problem i mention, same problem with switching to Internet TV channel or reverse.
here is a GIF video of this problem problem: http://mkerala.com/n/di/XN37/prog.gif
regards
#1463Still not can repeat this problem. Try rescan dvb channels.
#1464as i said before i tried to scan dvb channel again from base, but didn't help. what else you need for help?Prog wrote:Still not can repeat this problem. Try rescan dvb channels.
thanks
#1467FTA_Boy: And so, do you try rescan dvb channels?
#1468yes yes !Prog wrote:FTA_Boy: And so, do you try rescan dvb channels?
#1469Prog wrote:What indicators?
app cpu is always 0, sig. level not visible...New TimeShift status dialog with lot of new indicators (CPU, Memory,…).
#1470level fixed. app cpu very depended from system security settings.
