#1472
Prog wrote:Thex & FTA_Boy: Try last prerelease.
still having same problem :( , also i downloaded C pre-release but in about window it show B.
#1475
Can you repeat this problem on default settings? Special multi channel and TS settings. Please try install ProgDVB to new directory, scan and try.
#1476
tried what you said i have no problem with default setting for changing channel from DVB-s to IP/Torrent TV. but i dont know why too many different crash happens with default setting :( one of the crash logs :
crash logs.zip
(8.42 KiB) Downloaded 299 times
so we think there is something wrong with my settings, and here is my setting file you can test and take a look at it. i have problem with this setting:
settingProgDVB.zip
my setting , problem with switching channel.
(12.31 KiB) Downloaded 334 times
i will try change settings to find out what part of setting cause this problem and will let you know.
EDIT(post update): i found what part of setting was causing this problem: settings > Multi-Channels > The maximum quantity > Time shift buffers , value was set 1 changed it to 2 and problem solved. can you describe multi-channels and scanner(using of NIT) section what they exactly do ? this two section are confusing. thanks
#1477
hello again. there is new crash problem i think with version 7.04.3. when i open a Internet TV channel and change channel to DVB crash will happen and it will restart progdvb. here is the log. :
prev1.zip
(32.89 KiB) Downloaded 269 times
also when i'm watching a Internet TV channel and i change to another Internet TV channel ProgDVB will freeze for about 10second.
Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Method: Int32 Engine_SetChannel(ProgDvbEngine.TSetChannelParams*)
Stack:
at Engine_SetChannel(TSetChannelParams* )
at ProgDvbEngine.Engine.SetChannel(Channel channel, List`1 diseqItem, DateTime utcStartTime)
at ProgDvbNet.MainFormHelper.ActionList_SetChannel(CSetChannelParams _params)
at ProgDvbNet.ChList.Node.Do(ESetChildChannelMode mode, Boolean NeedSelectTreeList)
at ProgDvbNet.ChList.ChTreeGuiControl.ClickOnChannel2(ChannelNode node, ESetChildChannelMode mode)
at ProgDvbNet.ChList.ChTreeGuiControl.ChangeChannelClick(Point p, ESetChildChannelMode mode)
at ProgDvbNet.ChList.ChTreeGuiControl.ChangeChannelDblClick(Object sender, EventArgs e)
at IPDev.Skins.GUIChannelListView.OnNodeMouseDoubleClick(ChannelNodeMouseClickEventArgs e)
at IPDev.Skins.GUIChannelListView.OnMouseDoubleClick(MouseEventArgs e)
Extra details:
#1479
Prog wrote:Please send me ProgDVBEngine.log (to email) in next time. And netclient.log
i have sent you an email with thing you requested. i think this crash happen when InternetTV channel is opened and picture is freezed for buffering , meanwhile change channel to DVB channels (not sure about this) when it crash a message box will popup but quickly it will close. i will try to take picture from it!
edit : the message box saying:
title : error
text : "ProgDVB Engine API Except in ProgDVBEngine:Engine_SetCahnnel.
Regards
#1482
hello again. new crash report log, i was changing channels on DVB-S :
progdvb 7.05 - dot net framework : 4.5.2 - win7sp1
Message: Out of memory.
Method: Void .ctor(System.Drawing.Image, System.Drawing.Drawing2D.WrapMode)
Stack:
at System.Drawing.TextureBrush..ctor(Image image, WrapMode wrapMode)
at System.Windows.Forms.ControlPaint.DrawBackgroundImage(Graphics g, Image backgroundImage, Color backColor, ImageLayout backgroundImageLayout, Rectangle bounds, Rectangle clipRect, Point scrollOffset, RightToLeft rightToLeft)
at System.Windows.Forms.Control.PaintBackground(PaintEventArgs e, Rectangle rectangle, Color backColor, Point scrollOffset)
at System.Windows.Forms.Control.PaintBackground(PaintEventArgs e, Rectangle rectangle)
at System.Windows.Forms.Control.OnPaintBackground(PaintEventArgs pevent)
at System.Windows.Forms.ScrollableControl.OnPaintBackground(PaintEventArgs e)
at IPDev.Skins.SkinProgressBar.PaintBackground(PaintEventArgs pe)
at IPDev.Skins.SkinProgressBar.OnPaint(PaintEventArgs pe)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.UserControl.WndProc(Message& m)
Extra details:
prev1.zip
(27.92 KiB) Downloaded 305 times
#1484
Prog wrote:mpeg2 Video codec not good.
ffdshow video decoder not good ?! i don't like Microsoft DTV-DVD Video Decoder. ok
